Results 1 to 9 of 9
Thread: Model 41 hydraulic unit part numbers
    Buffalo Grove Il
    98
    Default Model 41 hydraulic unit part numbers
    I am going through the 2 valve 41 unit that I bought . I need the part numbers for the bushings that the control rods enter the unit. The unit has needle bearings in it but the seviceman reference book shows bushings. I have a sheet that the Cat parts guy gave me but the bushing are not shown. I need 4 bushings,4 seals, 2 retaining rings, the imput shaft seal, the big gasket and a filler cap. The serial number is 24C688 but it must of had a second valve added at some time. If anybody has a parts book for sale or a good copy I would be interested.
    Thanks in advance.
    Chuck Czaplewski
    847-459-3381
    7,056
    Early versions used bushings pt # 1H327 and seal # 1H326
    Later versions used bearings pt # 3H5076 and seal # 3H5077
    Buffalo Grove Il
    98
    Thanks OM. How do I tell the difference?
    Chuck C
    7,056
    You need a parts book and the serial number to tell.
    Actually I am referencing the 28C1, 29C1,30C1 (rear mount units) as I don't seem to have the front mount units manual but I'm pretty sure they followed the same sequence of part changes.
    Buffalo Grove Il
    98
    Thanks OM, the serial number is 24C688
    Chuck C
    NW California
    250
    Chuck,
    Your #41 will use the later parts OM listed,
    The ring that goes with the lever is 2h4146,
    Input shaft seal 1b2346
    Big gasket 1h0566
    filler cap 1h9588 and gasket 1h9589
    Buffalo Grove Il
    98
    Thanks Josh
    Buffalo Grove Il
    98
    I would like some pump info. The numbers on the pump are V-200-11-19D-12, 26 (all by itself) and S-19lh. Can anybody tell me the capacity of this pump? GPMs?
    Thanks in advance
    Chuck C
    7,056
    Those are Vickers parts numbers......might try giving a Vickers pump dealer a try.
  1. part numbers please
    By kiwicats in forum DISCUSSION
    Last Post: 02-19-2010, 08:30 AM
  2. Need Part Numbers
    By Frank L. Gross in forum DISCUSSION
    Last Post: 06-22-2009, 12:49 AM
  3. 44 hydraulic unit
    By waukman in forum DISCUSSION
    Last Post: 07-21-2007, 06:42 PM
  4. Part Numbers for A D-6 5R
    By bboaz in forum DISCUSSION
    Last Post: 07-14-2007, 04:53 PM
  5. Part Numbers For D2/3J
    By Dozerman51 in forum DISCUSSION
    Last Post: 12-19-2006, 08:43 PM
