Results 1 to 6 of 6
Thread: Pony cam gear install
    Nov 2007
    Redding CA.
    24
    Default Pony cam gear install
    Just got my replacement cam gear for my D47U Pony engine.Some of the teeth on the old aluminum cam gear were broke off so I do not know how to correctley time the cam gear to the crank gear.Did a search but no luck.What would be the correct alignment of these two gears?Thanks for any help. Don
    Default Camshaft
    The crank gear will have a mark and the cam gear will have two marks and the one is to line up with the crank gear the the other one is for the magneto gear to mesh with. I,ve put a truck load of them together but been so long ago since I retired I can,t remember what the markings are but look at them & I,m sure you can figure it out.
    Kerrick, Minnesota
    487
    Just worked on a D4 7U this morning, align the "C" on the cam gear to the "C" on the crank gear, and the "M" on the cam gear to the "M" on the mag gear.
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    Nov 2007
    Redding CA.
    24
    Default Pony reassemble
    Thanks SJ and Toby,that information is what I needed as I have never been inside one of these engines.So now it's parts cleaning for a couple of days then reassemble the pony and hope I did it right,thanks again,Don Alves.
    Nov 2007
    Redding CA.
    24
    Default Cam Gear Torque
    Well I forgot to ask the most important question,what do I torque the Cam nut to? Thanks again,Don Alves.
    Default Cam Gear
    If you tighten it up good and bend the lock over to hold the nut in place it should be enough.
  1. D2 piston install The sequel
    By 64farmboy in forum DISCUSSION
    Last Post: 04-20-2010, 10:31 AM
  2. D2 piston install
    Last Post: 04-17-2010, 06:09 PM
  3. pony motor elec. stater gear box issue
    By eric jensen in forum DISCUSSION
    Last Post: 07-12-2009, 09:06 PM
  4. RD4 4G Ring Gear/Starter Gear
    By Stuss in forum DISCUSSION
    Last Post: 03-14-2009, 03:52 AM
  5. Pony cam shim
    By STEPHEN in forum DISCUSSION
    Last Post: 11-07-2007, 08:15 PM
