Thread: 955 final drive ???
    Jun 2008
    ohio
    4
    Default 955 final drive ???
    i pulled the whole housing with the axle out how do i get the sprocket off i see a large threaded part on the outside off the sprocket is it pressed on
    thanks for ant info
    Default Sprocket
    You will have to take it to a Cat dealer or a place that has the HD puller setup to remove the sprocket from the hub as it,s not a back yard job as the special puller tools are needed.They are necessary to press the sprocket back on too with the correct tonnage.
  1. d2 final drive housing
    By mcarp in forum DISCUSSION
    Last Post: 10-28-2009, 11:23 AM
  2. D6 final drive questions
    By catd69u in forum DISCUSSION
    Last Post: 08-30-2009, 06:04 PM
  3. D-7 final drive seal
    By sidehill6600 in forum DISCUSSION
    Last Post: 11-21-2008, 09:18 PM
  4. Final Drive Nut
    By bernie in forum DISCUSSION
    Last Post: 09-15-2008, 11:12 AM
  5. D6 9U Final Drive Seals
    By Joel59 in forum DISCUSSION
    Last Post: 12-14-2007, 02:49 PM
