Thread: D3400 Fuel Line
    Nova Scotia
    122
    Default D3400 Fuel Line
    Is it possible, can a D3400 run on a 1/4" fuel line or should it be a 3/8?" I had one made at a shop, and they made the wrong size. Just wondering if it can be used or if I need to get another one made.
    Thanks for the help,
    Jim Legge
    in Nova Scotia
    California City, CA USA
    187
    Default Should work ok
    A 3400 engine probably burns only ~2 gal per hour under full load. That amount should flow fine through 1/4" tubing. Gravity purging/filter filling would take longer. The 3/8" line would would be less prone to vibration so the smaller line may need additional support (baling wire, nylon wire ties, etc.).
    Daron
    Nova Scotia
    122
    That's great, Daron, thanks for the info.
  1. D6 9U Fuel Line Problem
    By D6JP in forum DISCUSSION
    Last Post: 02-06-2010, 02:10 PM
  2. Late model D25U fuel line
    By Cysco in forum DISCUSSION
    Last Post: 10-29-2009, 07:12 PM
  3. 955H Fuel Return Line:
    By garythomak in forum DISCUSSION
    Last Post: 09-10-2008, 06:20 PM
  4. Pony Fuel line Help!
    By Jf3504x4 in forum DISCUSSION
    Last Post: 02-20-2008, 09:15 AM
  5. D2 Fuel line routing
    By chevymn1964 in forum DISCUSSION
    Last Post: 12-06-2007, 03:29 PM
