Thread: D6 9U 3405 Dry Clutch Adjustment?
    Ava Il.
    26
    Default D6 9U 3405 Dry Clutch Adjustment?
    I tried to adjust the clutch by losening the adjustment bolt on the clutch and had no luck in moving it. OM said it might be rusted. How can you tell if the clutch is fully adjusted? If it is rusted how is the best way to free it.
    By fully adjusted do you mean the limit of the adjustment????......when the adjustable collar bottoms out on the hub....there is no more.
    Usual method of soak, beat, pry and as a last resort heat (don't set the place on fire ) to get the collar to break loose.
    If you suspect it is bottomed out try rotating in opposite direction to get it loose.
    Ava Il.
    26
    Yes , the limit of adjustment is what I was asking about. Thanks I'll see what I can do.
  1. Re-lining D7 Dry Clutch - who does it ?
    By Billy D7 4T in forum DISCUSSION
    Last Post: 07-28-2009, 08:37 AM
  2. D6 9U Dry Clutch Flying Apart
    By d7doug in forum DISCUSSION
    Last Post: 05-15-2009, 04:48 AM
  3. D6 9U 3405 Dry Clutch Issues
    By First Cat in forum DISCUSSION
    Last Post: 09-06-2008, 01:02 PM
  4. D6 9U 3405 clutch adjustment
    Last Post: 07-19-2008, 10:36 PM
  5. Dry Type Clutch questions
    Last Post: 04-20-2007, 05:28 PM
