Thread: D6 9U 3405 clutch adjustment
    Ava Il.
    26
    Default D6 9U 3405 clutch adjustment
    Thanks Old Magnet The soaking and a pry bar with a few tap of the hammer and the adjustment was a success. It moves freely now. should the clutch adjustment bolt be torqued and if so any idea of the pounds?
    7,113
    There is no recommended torque for the dry clutch....just the oil clutch.
    Use your own judgment.....should be tight but not over done. They rarely get loose on their own.
  1. D6-9U Clutch adjustment HELP
    By DerekCT in forum DISCUSSION
    Last Post: 11-09-2009, 02:01 AM
  2. 30 clutch adjustment
    By Jason 10/D4 in forum DISCUSSION
    Last Post: 04-14-2009, 06:39 PM
  3. D6 9U 3405 Dry Clutch Issues
    By First Cat in forum DISCUSSION
    Last Post: 09-06-2008, 01:02 PM
  4. D6 9U 3405 Dry Clutch Adjustment?
    Last Post: 07-18-2008, 05:13 AM
  5. Clutch Adjustment
    By vernier in forum DISCUSSION
    Last Post: 05-06-2007, 08:09 AM
