Results 1 to 3 of 3
Thread: Clutch Brake on Starter Clutch and Pinion
    Nova Scotia
    122
    Default Clutch Brake on Starter Clutch and Pinion
    Regarding my D2 J Series, I seem to have a problem slowing the pinion down and up to engage it into the flywheel. Is there an adjustment on the brake or is the adjustment only on the clutch? The clutch has a good over center snap to it. If the clutch is a little too tight, could that affect the brake?
    Thanks for the help,
    Jim Legge
    Kerrick, Minnesota
    487
    Default Pony clutch
    There is no adjustment on the pony brake that I am aware of. There was a post a while back that contained some good tips regarding this problem. Try to use the search feature to find a post titled "Pony Motor Engage". It is about a D4 but the information will also apply to your machine. It talks about different weights of oil you can try in the clutch compartment as well as some adjustments that can be made.
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    Nova Scotia
    122
    I found the post you mentioned about the Pony Motor Engage, thanks so much for the help.
    Jim Legge
  1. D2 Starter Clutch and Pinion
    By novavalleycat in forum DISCUSSION
    Last Post: 09-30-2009, 07:23 PM
  2. D4 5T Clutch Brake
    By carlsharp in forum DISCUSSION
    Last Post: 10-15-2008, 10:20 AM
  3. D2 Clutch Pinion Seal
    By oldparker in forum DISCUSSION
    Last Post: 09-17-2008, 08:16 AM
  4. Starter Clutch and Pinion
    Last Post: 08-25-2008, 12:09 PM
  5. Clutch and Pinion on D2-J Series
    Last Post: 11-17-2007, 08:02 PM
