Results 1 to 6 of 6
Thread: BEST 60 Logging Cruiser
    Australia
    166
    Default BEST 60 Logging Cruiser
    Hello All, i have a question !,, Do any one know if the Best logging cruiser with the cruiser top , did they all have the heavier drawbar and bigger front idler springs??, or did Caterpillar put that on after 1925 ??. I am putting a cruiser hood on my transition Best 60 , it has the normal springs and drawbar... Thanks. Peter
    1,588
    Those are handsome beasts! So far as I know, to be a true logging cruiser, it has the heavier springs. I was never aware that the drawbars were heavier too. I've always wondered at the utility of the buggy top. Perhaps in western (open) forests, the buggy top would be OK, but in eastern forests, the lower branches would tear off the buggy top. Glad you have a logging cruiser.
    BTW, there was a very large lumber company in the west (Red River Lumber Co.???) that used Sixties, and fabricated their own improvements to the basic 60 - and Cat adopted the improvements. Such as extra heavy pads.
    GWH
    Sep 2008
    alaska
    3
    Default best 30
    would you have any idea what a best 30 would be worth?
    769
    Pete, near as I can tell from the literature I have it would have a tow hook, heavy radiator screen and the buggy top. Most of the heavy duty stuff like the rad, tank saddles, scavenge oil pump, springs etc came along in 1928.
    BEST TRACKLAYERS ARE #1
    Australia
    166
    Default Transition 1925, Best Cruiser
    Thankyou for the replys friends, i will get some pictures in next week or so.. BEST wishes to you all ,,, Peter,
    Australia
    166
    Default Best Cruiser
    Another very interrestring thing i found on this tractor !, on the brass info tag on flywheel guard-cover, it has {Cruiser} written ,in brackets at top corner , also it has on gear-shift pattern, H for high not like the normal 3 for third. As the cruiser do have a higher top speed. A lovely tag . Lucky it wasnt gone Hey !?. Have any seen that tag on other tractors?. I was wanting to ask Doc Sheppard in Fl if his Cruiser had that tag ?. Regards to you all . peter
  1. BEST 60 Cruiser
    By D6 Pete in forum DISCUSSION
    Last Post: 12-06-2011, 09:32 AM
  2. Cruiser pics
    Last Post: 10-03-2008, 03:46 PM
  3. Logging in
    By Shetland Sheepdog in forum BULLETIN BOARD OPERATIONS
    Last Post: 05-09-2008, 07:15 PM
  4. Cat 60 cruiser hood braces
    Last Post: 10-26-2007, 02:09 AM
