Thread: D2 Front Hydraulic Pump Specs?
    Jul 2008
    Schenectady, NY
    4
    Default D2 Front Hydraulic Pump Specs?
    I'm the proud new owner of a '47 D2 4U (4384).
    It has a straight blade, driven by a front hydraulic pump that's buried in the hydraulic oil reservoir, under the protective grill.
    Does anyone know what kind of flow rates and pressures this thing might have? I'm guessing about 10 gpm up to 3000 psi?
    I note that Northern Tool has hydraulic motors for $104, and I have dreams of making hydraulic-motor-powered gadgets.
    Further:
    10 gpm at 3000 psi works out to 17.5 horsepower. If I can stop the diesel engine with the hydraulics, does this imply that I'm only getting about 20 hp out of my 61 year old engine?
    -Rob
    7,049
    They used the #44 Cat Hydraulic Unit.....low pressure, high volume. Hydraulics were not really all the well developed at the time. Also they used vane type pumps which slip at low rpm and reduce the cold starting load.
    There was also a #41 Hydraulic unit of considerably less flow but would be a little slow for the regular straight blade unit.
  1. No. 41 hydraulic pump
    By gwhdiesel75 in forum DISCUSSION
    Last Post: 12-19-2009, 01:40 PM
  2. Hydraulic pump for the D2 3J
    By novavalleycat in forum DISCUSSION
    Last Post: 11-19-2008, 11:32 PM
  3. Front Hyd Pump
    By OCB in forum DISCUSSION
    Last Post: 09-08-2008, 04:03 PM
  4. Hydraulic Pump Pressure
    By First Cat in forum DISCUSSION
    Last Post: 08-16-2007, 10:14 PM
  5. 41 and 44 Hydraulic Pack Specs
    By NZCat in forum DISCUSSION
    Last Post: 07-07-2007, 05:08 AM
