Hello guys;
I was moving my D4 back and forth to try to break the steering clutches loose,No luck.When I stopped after about 30 min.I shut it down,Then I noticed that the antifreeze was pouring out the overflow tube on to the ground.I think that the water temperature regulator is stuck,frozen whatever.In the book they use a special tool #3B7184to remove the retainer in the pipe.How do you remove the retainer if you don't have the tool? Can you still buy it,are there other tools that will work? Such as a Gear Puller,Or do I have to make my own? Also this D4 has the Hyster4DN wench on the rear with the extened tubes to fill the Final Drives.How do you tell when you have enough gear oil in the rears?I can't see down the pipe to check as it bends.
Any thoughts on these problems? Thanks STEAMROLLER
