Results 1 to 6 of 6
Thread: 1936 cat 22
    Sep 2008
    ohio
    5
    Default 1936 cat 22
    Runs alittle rough at times but hopfully with some work it will pure like a kitten!
    Sep 2008
    Newfoundland, Canada
    40
    Great looking Cat. How about some more pics of the blade and pto hydraulic pump set up.
    Sep 2008
    ohio
    5
    Will this do?
    Elkhorn, WI
    1,645
    Default Nice Tractor!
    But tell her she is prettier than the tractor!
    Or she won't let you play with it anymore!
    Aug 2008
    Nampa, ID
    49
    To make it run smoother, try adjusting and cleaning the points in the magneto, clean or replace the sparkplugs ($3.00 each at Car Quest), run aviation gas through it if you have varnish issues, retorque the head, adjust the valves, then hook onto something heavy and run the crap out of it. I couldn't get the temperature of the engine up so I put a towel over the radiator when I ran it hard, and that alone solved a lot of problems. These engines want to work hard and they don't like a lot of ideling. I did all of the above and mine runs sweet.
    Now-- I have to find an operator that looks that good and I'll be set.
    Sep 2008
    ohio
    5
    Took the magneto off to get it redone and the guy said the coil was bad so that should make a big difference when we get it back together!
  1. 1936 Citrus Twenty Two runs again
    By WyoCat in forum DISCUSSION
    Last Post: 11-27-2011, 01:34 PM
  2. Replies: 8
    Last Post: 09-23-2008, 02:09 PM
