Thread: D4 5T Clutch Brake
    Sep 2007
    Chino Hills, CA
    270
    Default D4 5T Clutch Brake
    The old D4 has no clutch brake function to speak of. Is there an adjustment? And in the meantime, is there any trick to stop the trans from spinning? Once in a while I'll miss that clean shift and it takes forever to stop. I guess the bearings are good!
    Carl Sharp
    Chino Hills, CA
    2xPV15; 3x22 2F; D2 4U; D2 5U; D4 5T; JD Model D; Ford 8N; Various other oddball stuff
    Vids: http://www.youtube.com/profile?user=carl4043
    Please visit my Ebay Store, Vintage Rust & Relics
    http://stores.shop.ebay.com/Vintage-Rust-and-Relics
    Hi Carl,
    You can fiddle with the threaded yoke adjustment down in the clutch hole to get the best range of travel to activate the brake and over center function and the position of the clutch hand lever. Check the wear on the brake shoes....they should be replaced if worn down to the flat head screws.
  1. D7 3t sparks behind clutch brake?
    By nebraskafarmer in forum DISCUSSION
    Last Post: 10-22-2009, 09:19 AM
  2. 22 Brake Band & Steering Clutch Removal???
    By Peter Mercer in forum DISCUSSION
    Last Post: 03-08-2009, 05:46 AM
  3. clutch brake adjustment on Caterpillar 22
    By chugwater crawlers in forum DISCUSSION
    Last Post: 01-02-2009, 02:20 PM
  4. Clutch Brake on Starter Clutch and Pinion
    By novavalleycat in forum DISCUSSION
    Last Post: 07-23-2008, 11:09 AM
  5. brake work on d2
    By beekman in forum DISCUSSION
    Last Post: 08-23-2007, 09:01 PM
