Thread: D42T Test Run...
    Indiana
    360
    Default D42T Test Run...
    Took my first run on the D42T this evening in about 16 months...felt good. The starting engine operated fine and pulled the main over. Fuel and oil pressures in good operating range.
    Went out this afternoon planning on wrapping things up. Adjusted the main clutch. That took a while but I was able to take off the top of my bikini cover and access everything. I also adjusted the latch screws on the starting pinion. The clutch appears OK-it snaps back good. It never has for me until now. There is sure a sweet spot between too much and too little. It held fine. The levers fall right under the locks from the gear box after the adjustments to the clutch.
    The starting pinion stayed engaged very well. I think it may need another half turn. I did not want to go too far with it. You can laugh, but one of the set screws in the latch was absolutely froze. Applied heat and PB Blaster with no result. Unable to move it, guess what I used...CANDLE WAX! Freed right up. No kidding.
    Topped off the gear box oil and decided to look underneath to make sure nothing was leaking...I'll be dogged but diesel was leaking at a pretty good rate! Could not believe it. I began looking around starting at the on-off valve as I swapped out the drain valve for the ON-OFF, (another story). Anyway, the metal fuel line turned out to have a pin hole in it. That is why it ran out of fuel the other eveing I am sure. A trip to lowes for tubing at 8:30 and spliced in a section. No leaks.
    Got the starting engine going again and ultimately the main. Let it idle at half thorttle for about fifteen minutes while I was taking down the truss I built to set the tran cover. Took it for a whirl. Got it back in the barn and adjusted the clutcehes and brakes a little more. I will see tomorrow how well it does. It did fair tonight
    Thanks for the help to get me to this point.
    I am so glad I cut that cover. I was able to remove it without removing the starting engine flywheel OR the dash. I just loosened the dash.
    bernie
    Eastern Oregon
    966
    Congrats Bernie. .I imagine it feels good to be able to get 'er going once again. It will take some time and use before those steering clutches and main clutch "settle in". .be ready to do some more adjusting as time goes by. Glad ya "got 'er done" lad. .
    Southern Illinois
    57
    Default Good news always welcome
    I hope you get to use it before the mud season starts.
    On the fuel line, Continue to watch as the copper we can easily buy gets brittle from flexing/vibration.
    I hoping nothing new comes up this week and I can get mine back together. But sickness and the predicted rain may keep me finishing the the work next to the pond till next fall..
    Default For Bernie
    Bernie, did you tell me once you live in the Martinsville area? My son lives in Avon and a friend of mine that lived here in Dallas Pa. now lives in Waverly but his address is Martinsville. The last he told me he worked for a Bob Cat dealer there someplace in the area.
    Indiana
    360
    SJ-
    Yes, we are in Monroe County, just south of Martinsville.
    bernie
  1. Caterpillar D2 Test Run
    By QuAD in forum DISCUSSION
    Last Post: 06-03-2010, 04:18 PM
  2. D7 4T will not run
    By jsclampit in forum DISCUSSION
    Last Post: 04-05-2009, 02:30 PM
  3. can d2 engine run alone?
    By abram in forum DISCUSSION
    Last Post: 02-21-2009, 09:13 PM
  4. What would you want to run for a day
    By hicrop10 in forum DISCUSSION
    Last Post: 05-29-2007, 04:55 AM
  5. test run
    By beaver-flat in forum DISCUSSION
    Last Post: 11-28-2006, 08:19 AM
