Results 1 to 10 of 10
Thread: D4 block heater
    Jun 2008
    jackson ohio
    81
    Default D4 block heater
    Help Needed??? Is there a block heater for a D4 7U? If so, where should I look? Any and all help is appreciated.
    7,055
    Most of em used an external circulating type.
    Try Googling the "Watlow" brand......if I got the name right
    Plains of NW Kansas
    305
    Cowboy, MB. Cat hooks up the heaters as shown in the two photos linked below. I plan on doing the same to my D47U when I can get to it.
    Looks like a pretty easy installation except for drilling and tapping the head of the pony 1/2" NPT. The other end attaches to the lower radiator supply at the tapped hole that is already there.
    These are John's (MB. Cat) photos.
    http://img217.imageshack.us/my.php?i...eater01wn5.jpg
    http://img217.imageshack.us/my.php?i...eater02yp7.jpg
    I have several Kats that seem to work OK.
    http://www.northerntool.com/webapp/w...9137_200339137
    D4Jim
    7,055
    On the "U" models it's more common to run a circulation circuit from the flange on the side of the thermostat housing to the pipe plug fitting on the lower radiator pipe.....no taping required.
    Plains of NW Kansas
    305
    Default Thanks OM
    OM, That looks like it would be even simpler. I was wondering if that would work. Looks like all one would have to do is drill a hole in the flange cover plate and weld a coupling to the plate or even a short nipple for that matter.
    D4Jim
    North of Casper, Wyoming
    111
    Default external heater
    On my 7U I ran a hose from the plug on the lower radiator hose to the drain vent on the top of the starting engine. The water circulates nicely through both engines.
    7,055
    That will work to.....but be sure to check either approach to see that the pony cylinder area is getting heat and not plugged up with the usual sediment
    Jun 2008
    jackson ohio
    81
    Default engine heater
    Thanks for the info. I would like to find an element to screw into the lower pipe. Dont know if anyone makes one.I have two of the tank type on other equipment.
    Eastern Oregon
    966
    The last 7U that I bought has an inline heater plumbed from the lower pipe to the left side of the block, right behind the governor.
    148
    Today I installed a " Kat " brand heater on my D2... will attach to the engine side panel with a U-bolt. I ran the heater long enough to insure that it worked, but not long enough to really warm the engines.
    Because I'm adding direct electric start for the diesel engine, and don't have glow plugs, I thought it would help with the first startup of the day.
  1. block heater D2
    By eric jensen in forum DISCUSSION
    Last Post: 02-09-2010, 09:03 PM
  2. D4 7U block heater
    By power stroke 99 in forum DISCUSSION
    Last Post: 07-06-2009, 11:04 AM
  3. Cracked Block?
    By Radcam in forum DISCUSSION
    Last Post: 03-02-2009, 02:46 PM
  4. D7E coolant heater
    By poor farmer/logger in forum DISCUSSION
    Last Post: 01-12-2009, 09:17 PM
  5. D25U heater removal
    By tomseabee in forum DISCUSSION
    Last Post: 12-18-2006, 06:17 AM
