Thread: Cat 22-Broken Brake Adjusting Rod
    Sep 2007
    Chino Hills, CA
    270
    Default Cat 22-Broken Brake Adjusting Rod
    I was getting a 22 that had not run in 10 years ready for my playday. I went to adjust the RH steer brake, I used Kroil and tried gently with an end wrench. Then the rod twisted right off. I was really disappointed as I knew what this meant, and everything had gone really well up to this point.
    I know some of you may disapprove, but after much thought this is how I fixed it without dismantling a third of the tractor:
    CS
    portland victoria australia
    866
    Default cat 22
    hello carl ,it a cat ,8 lives left ,mate has a 22 that throw no3 rod ,it has a plate tex screwed over the hole ,it's still going after replacing broken parts ,bruce oz
  1. Looking for a rod bushing for Cat 30
    By MarkB in forum DISCUSSION
    Last Post: 07-30-2009, 05:17 AM
  2. Cat 22 locked/broken steering brake?
    By Peter C in forum DISCUSSION
    Last Post: 11-13-2008, 12:23 PM
  3. Cat 22 Rod Bolt Torque Specs
    By dmgrow in forum DISCUSSION
    Last Post: 04-13-2008, 09:34 PM
  4. CAT NOS 6F1945 D8 rod bearings
    By CAT RD-7 in forum DISCUSSION
    Last Post: 03-07-2008, 08:55 AM
  5. Need clearance, Cat 10 rebuild, rod & mains
    By Steve A in forum DISCUSSION
    Last Post: 08-22-2007, 06:17 AM
