Results 1 to 7 of 7
Thread: Rope start
    turlock ca
    137
    Default Rope start
    5J pull pony and main turns over bad clutch or ajustment.?
    Default Clutch
    Make sure the pony clutch is in the released position and if it still turns the diesel then something is hanging up in the clutch so you,ll have to check deeper into why.Make sure the clutch compartment has oil in it and if not it must be seized up in there.
    Eastern Oregon
    966
    If it still tried to turn the main, drain the oil in the clutch and dump in some diesel. Try it again a few times, then drain the diesel and refill with automatic transmission fluid. If it still drags the main, readjust the clutch as it might be too tight. All the clutches on my critters "snap" in with very little effort.
    Nov 2008
    South Australia
    117
    Default Clutch
    I had the same problem [ seems to be common ] I adjusting my clutch using the manual. Try pushing the lever to the rear of the tractor [clutch brake]. This does take two people though if your trying to start the pony.
    Billy
    Nov 2008
    ontario
    2
    Default Rope Start
    It sounds like the abendix is seized.Is the lever for engaging the pup to diesel moving freely or is it pulled intoward the seat.
    Elkhorn, WI
    1,675
    Default Unclear?
    Actually his statement is vague?? Could he have engaged the bendix and be relying on the Pony Motor clutch to be the disengagement point? I know on mine it will drag big time if the oil is too heavy which in effect is rolling the Main over when you pull the rope? I believe the problem is in the pony clutch.
    Nov 2008
    ontario
    2
    Default rope start
    On my D2 there is two levers clutch and abendix engagement.If the abendix is disengaged the clutch will not be able to drive the diesel flywheel .
  1. Rope start to electric start pony for a D2 4U
    By D24U in forum DISCUSSION
    Last Post: 04-21-2010, 04:23 PM
  2. 51 D2 won't start
    By tracknut in forum DISCUSSION
    Last Post: 05-05-2009, 05:28 AM
  3. D2 Pony start to direct electric start
    By hicrop10 in forum DISCUSSION
    Last Post: 11-01-2007, 08:42 PM
  4. D6 9U Direct Start
    By Don Clark in forum DISCUSSION
    Last Post: 08-27-2007, 06:39 PM
  5. new start
    By bruce oz in forum BULLETIN BOARD OPERATIONS
    Last Post: 06-26-2007, 07:10 AM
