Results 1 to 7 of 7
Thread: D8 2U rail height specs
    Aug 2007
    northeast Iowa
    34
    Default D8 2U rail height specs
    I'm looking at a D8 2U and the rail height is 4 5/8 inches. What should the rail height be when the rails are new? What is the percentage rate on these rails at 4 5/8 inches?
    Default Link Height
    RD-7, it depends on the link numbers but here's a couple of measurements
    link * 2H953/4 - new link height 4.75" - 100% worn 4.38"
    7H3799/800 - new link height 4.88" - 100% worn 4.55"
    Hope this helps. cheers Al
    7,056
    Can you get a link part #?....I show three different height rails that were available. The oldest (and lowest orig. height) is a 2H953-54)......started out at 4.75 in. and .37 allowable
    % worn = amt. worn/allowable = 34% worn in this case.
    Aug 2007
    northeast Iowa
    34
    I can get a part number one of these days for the link. These are the early style rails that the 1H's, 8R's and 2U's had.
    Aug 2007
    northeast Iowa
    34
    So is there 3 different rail heights for the same pitch rails?
    7,056
    Yes, all three are for 8 in. pitch.
    Two have been covered, the third is a #1S8839 & 40
    New height is 4.97 in. allowable wear is 0.380 in.
    Aug 2007
    northeast Iowa
    34
    Thanks for your help...It looks like I need to get the part number off of the links to get an accurate figure...
  1. Liner height
    By CR in forum DISCUSSION
    Last Post: 12-19-2009, 01:48 PM
  2. link height
    By bobdawson in forum DISCUSSION
    Last Post: 07-19-2009, 04:37 AM
  3. Caterpillar Ten Rail Height
    By JasonPayneCrawlers in forum DISCUSSION
    Last Post: 01-16-2009, 08:35 AM
  4. Does This Rail Fit A D6 9u?????
    By King of Obsolete in forum DISCUSSION
    Last Post: 09-04-2008, 08:39 PM
  5. Liner height on D 13000
    By XtremeXcavator in forum DISCUSSION
    Last Post: 03-18-2007, 11:15 AM
