Results 1 to 10 of 10
Thread: Direct electric start on a late 5J?
    Bangor PA
    25
    Default Direct electric start on a late 5J?
    I see a casting area under the pony engage lever that looks like maybe a electric starter can be mounted with a bit of machine work. Is this possible? Anyone have pics of a starter on a 5J?
    7,047
    Yup, that's where it goes.
    Here's all you want to know (and some you probably don't)
    http://img400.imageshack.us/gal.php?g=header4oq.jpg
    San Luis Obispo,CA.
    82
    I have an accsory book for the tractors of that time period from Cat and it shows the electric kit for a 5J.
    191
    2 questions
    1} is it possible to have both the D/E start and a pony motor, or does the starter pinion location preclude it?
    2)Has anyone ever seen a direct electric start on a 1V series DW10? Mine has a bolt on cover on the bellhousing for one, but I can't see how it could fit, as the steering box seems way too close to that location, on the inside of the frame rail.
    Just wondering,
    alan627b
    Default D10
    I don,t have any parts books to run down bell housing numbers but it,s possible the same bell is used on other applications of the engine. It should be a D318 engine in it so the D6 8U & 9U use that engine & also in industrial uses.
    7,047
    Hi Alan,
    On question # 1,
    So long as there is a raised boss provision on the bell housing there is no problem having both either with the original type starter or the 40,42,50MT conversions with one exception.
    On the D2, if you want the deluxe installation that allows you to run the factory original engine side covers without modification the fit is to close to the pony clutch operating lever and cover which needs to be removed and blanked off.
    You will have to find a home for the batteries if you run both.
    On question # 2, I don't know about the DW10 but any of the above starters will mount to the D318. See my website for the indexing.
    Default Location
    SMF52, I see you live in Bangor so your up in the Poconos so your not far away. I live up in Dallas & I worked for Cleveland Bros. for 36 yrs. and retired the end of 1991. I ran the engine rebuilding shop there at the Wilkes Barre shop. We had lots of customers up in your area & around the Poconos.I don,t know if you knowed it but Cleveland now owns Beckwith Machinery Co. the Cat dealer in western Pa. so now they have more than 25 branch stores now. With your question about the starter OM that come back to you is the guy that knows about starters & changeover of them.
    Bangor PA
    25
    OM thanks for the info, I bought a MT 42 starter and the Cat helical starter drive. I am still looking for and researching the drive end housing. I believe the offset housing is also known as a SAE #1 housing. I will most likely just order the 512-135 from Barsanco.
    SJ Thanks for the info, I am rebuilding/restoring a 3J and 5J crawler and have been looking for a Cat dealer that will be helpful in finding these old parts.
    7,047
    I have been having trouble opening the Barsanco website. Have you???
    If so you could try the CPC source.
    Default Parts
    SMF52 this guy over in Montoursville Pa. near Williamsport is in to old Cats & also makes some sheet metal parts for them so he may be able to help you either with some parts or some info. where to get parts.His name is Geo. Logue & his number is (570) 368-2639 He also has a museum of old Cat machines & I saw a while back that the ACMOC chapter from NJ visited his museum.
  1. New Method of Direct Electric Start
    By alan627b in forum DISCUSSION
    Last Post: 04-18-2010, 12:12 AM
  2. D4 direct electric start conversion
    By power stroke 99 in forum DISCUSSION
    Last Post: 12-03-2009, 01:52 AM
  3. D2 Pony start to direct electric start
    By hicrop10 in forum DISCUSSION
    Last Post: 11-01-2007, 08:42 PM
  4. direct electric start for D8 13A
    By baanhuus in forum DISCUSSION
    Last Post: 07-27-2007, 06:47 PM
  5. Cost of direct electric start conversion
    By ol Grump in forum DISCUSSION
    Last Post: 07-14-2007, 12:06 PM
