Results 1 to 10 of 10
Thread: Serial number location on Cat 30
    Mar 2008
    Rangiora ,New Zealand.
    32
    Default Serial number location on Cat 30
    Can anyone tell me where the serial numbers are stamped on Cat 30 , we don't have the ID plate on the fender,thanks
    Mar 2008
    Ont. Canada
    45
    There are three spots on my 30. On the left side of the engine block below the carb,rear of the transmission shifter cover there is a machined flat spot with serial numbers stamped in it, the third spot is above where the pto would attach at the rear of the machine. Hope thats of some help to you.
    Default Serial # location on 30
    I've also seen them stamped on the block above the main clutch behind the last cylinder jug
    Mar 2008
    32
    Default Cat 30 what year ?
    thanks guys , I found a number under the waterpump on the block S 1446 it is a cast number not stamped ,and 975 is stamped on the back of the rear housing just in front of the seat bracket (orchard model ) Can some one now tell me what year it was built ?
    Mar 2008
    Ont. Canada
    45
    Default 30 serial #
    If it has PS in front of the number then it should be the serial no., my book said it would be 1927.
    Napa Valley - Newville CA
    844
    You better look again and look for a P in front of the S or another digit in the number. S1446 would be a 1922 Best30 and would make ie a 2 speed and worth about $20,000 more then your Cat30 LOL
    Hello, s-1446 is the part number for the engine block, not a serial number.
    Mar 2008
    32
    Default serial no Cat 30
    thanks again all , caterpillarman : I thought that maybe it could be the part no for the block number also, not the serial no,thanks for pointing that out .--- Willie, Ive looked hard and there is no S or PS in front of the 975 stamped on the rear housing and it is a 3 speed with 2 sliding gear levers, so its not a Best, pity. My cat 10 also has the numbers only, no letters in front, so perhaps it's the same , I'll have to keep looking, you keep sending in ideas ,Andy
    844
    That no. stamped on back of block is supose to be date it came off the line but I have never figured it out. but the ser. no. will be stamped or on a tag not embossed in casting and unlike later machines the didnt stamp under the tags,look close on top of PTO housing for stamped no. or little tag behind the carb.
    Mar 2008
    32
    Default ageing a Cat 30
    Willie :Had another good look for more numbers but no luck ,there is definitly no letters with the numbers on the back of the trany, only 3/4 inch high 975 stamped ,so I'll just have to settle for 1927 . It has had the steering levers out the side but they have been cut off and levers fitted like most tractors have at the back , I'll refit the original type when I find some, cheers Andy
  1. 2 ton serial number location?
    By kiwicats in forum DISCUSSION
    Last Post: 09-18-2009, 03:31 PM
  2. Cat 10 Serial Number
    By Member2103 in forum DISCUSSION
    Last Post: 07-20-2007, 12:43 PM
  3. Serial Number Location on 3406
    By Art From De Leon in forum DISCUSSION
    Last Post: 06-30-2007, 07:56 PM
  4. Serial Number Location on No 25 CCU (32E)
    By David Wills Cat 60 in forum DISCUSSION
    Last Post: 02-28-2007, 02:43 PM
  5. cat serial number
    By tazm in forum DISCUSSION
    Last Post: 12-09-2006, 10:45 PM
