Results 1 to 7 of 7
Thread: pony delivery!!
    Oct 2008
    placerville
    59
    Default pony delivery!!
    hey folks i got a quick Q...i'm still trying to figure out a way to get my neighbor's D2 to my place to work on it...the main is not running currently but i probably can get the pony going without much effort, i was wondering if it is possible to USE the PONY to get the crawler rolling to my place? i've heard stories of people using the pony to get the tractor on a trailer, but i'm not sure if its got enough power to pull it up an incline... i know it generates around 10HP while the main produces about 30 whadda all think?? BTW before i would attempt this i would lighten the machine as much as possible (main's pistons, cam, conrods, head (although i would need to figure out how to cool the pony))
    3J5 D2
    Elkhorn, WI
    1,640
    Default Tractor or 4WD???
    Somebody you know must have a 4WD pickup that they think is the greastest pulling truck in the world. A little beer may give them the incentive to hook up and try to move it for you. Depending on the distance, I'm thinking the pony may not live a long life after your adventure.
    Eastern Oregon
    966
    If you've got the main torn down, I sure wouldn't be using the pony more than a couple of seconds. No cooling means that it's gonna fry in a short time. . With coolant in the engine(s) I've moved my old D2 a few times, but not more than a few yards.
    Oct 2007
    Virginia
    253
    I've used the pony to move the tracks when removing them or walking them back on, but never moved the crawler with it. It goes really, really slow in first gear. But, it would probably do it ok if you put the machine in 1st gear and get your trailer real close. I wouldn't try to drive a long distance though. You are taking a chance on breaking something down in there that requires removing the engine to be able to make the repair.
    Years ago I bought a non running 1957 D7-17A, got the pony running and then used that to drive it up onto the lowboy. The lowboy had a winch, but it couldn't get the machine up the ramp without the help of the pony. I guess it was the winch and pony moving the machine, which probably saved the pony drive gear. Though the winch cable was slack most of the time. Some dumb luck was at work.
    Southern Illinois
    57
    Default Pull it
    I pulled my D42T up a 25% grade with a JD 60. 38 HP but didn't need it and 5000 pound and that was plenty.
    Arthropod. If you said about 1957 you loaded a D73T in the way you stated, I would respond I watched you. Neither the wrench or the pony wouldn't do the job by itsself but 2 man and a boy got it loaded.
    Perth, Western Australia.
    897
    abram - I wouldn't do it. The pony just isn't built to haul the tractor along, and most certainly not up a beaver tail onto a trailer. It's no different than using your car starter to try to do the same.
    A 4000 lb electric winch is quite capable of pulling a D2 up onto a trailer, if the tractor rolls O.K. If needed, you can use a snatch block to increase the line pull, and/or reduce the winch load. You haven't stated how far you have to move it? .. and whether you were just going to try and drive it a distance, or trailer it.
    Oct 2008
    placerville
    59
    gotcha, not going to attempt it
    3J5 D2
  1. Late Delivery of the ACMOC Magazine
    By gwhdiesel75 in forum DISCUSSION
    Last Post: 02-23-2008, 03:51 PM
