Results 1 to 10 of 10
Thread: D2 Pictures (the old girl runs again)
    Springfield VT
    22
    Default D2 Pictures (the old girl runs again)
    After 2 1/2 years I finaly got my D2 back together. We had a bright sunny day on thersday and I was able to get some nice crisp pictures before I put it to work. It will probably never get that clean again.
    Elkhorn, WI
    1,640
    Default Nice Job!
    Are you going to put a brush guard on the radiator before you poke a limb through it?
    As I assume you are going to be in the woods.
    1,783
    Large front ilders? 5 roller track frames. Do you have a dozer? It changes the whole look of the tractor compared to the 4 roller frame and the small idlers.
    Nice!
    Kerrick, Minnesota
    487
    Nice looking D2, that looks ready to do some real work, too. With that Hyster winch and long track frames I bet it's a pretty stable machine to operate. Good job!
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    Jan 2008
    Burley, ID
    156
    Beautiful work. That looks really nice.
    long island NY, Hancock Ma
    637
    Very very nice--what is the serial # of your machine
    cat 941B, Cat D2 4U7412, Cat D3B, D4 7U30755
    Nov 2007
    NW Ohio
    495
    Default D2
    Was that a pipelayer at one time?
    Springfield VT
    22
    For my next project I am intending to put a grauser blade on it so when I put the pump on I'll put the brush guard on the radiator. I probably should have biult the blade instead of painting it but I sure looks pretty .
    I am not sure what size the idlers are. Thay are certinly bigger than they used to be when my grandfather and I over hauled the undercarriage ten years ago. We biult them up with some 1/2" 1" stock that we rolled into rings and welded onto the idlers.
    I'll see if I can measure the idlers tomorrow and I'll check the serial number. If I remember right, it was manufactured in 1952.
    Feb 2008
    Portland OR
    87
    If you build the blade close as possible to the tracks and radiator, you will have one of the best grading D-2's on the planet. I would spend the time and your $ to make it a hyd. tilt too. What a wonderful looking Cat! firpitch
    Springfield VT
    22
    the serial # is 5U 3993
    My grandfather said that this D2 was originaly set up for logging with a scoot. You can still see where the frame that suspended the pulley over the scoot was attached to the insides of the track frame. I've seen one D2 set up this way but unfortunately I didn't get any pictures.
  1. Girl on a cat
    By Painter in forum DISCUSSION
    Last Post: 09-11-2009, 07:57 PM
  2. Diesel 35 runs again!
    By miked238 in forum DISCUSSION
    Last Post: 03-24-2009, 12:41 PM
  3. D2-5J Runs!
    By drujinin in forum DISCUSSION
    Last Post: 01-29-2009, 04:30 AM
  4. Cat 20 runs
    By equipdriver in forum DISCUSSION
    Last Post: 11-19-2008, 04:51 PM
  5. 22 Cat Runs Again
    By dmgrow in forum DISCUSSION
    Last Post: 07-23-2008, 10:57 PM
