Thread: D4 Final Drives
    Sep 2007
    Lindsay, Texas
    85
    Default D4 Final Drives
    I was wondering if a final drive of a 5T D4 is the same as a 7J D4? will they interchange?
    Thanks,
    Pat
    Pat Bayer
    1938 R4 Caterpillar,1937 RD4 Caterpillar,1938 RD4 Caterpillar,1942 D4 Caterpillar, 1930 30, Gas 50
    7,057
    No, there were major changes to the whole set up when they went from small to large track truck bearing arrangement.
    Perth, Western Australia.
    897
    R4Pat - The final drive design of the D4 was changed almost totally in early 1945, at D4 S/N 2T8270. This new design, with an easily distinguished, large outer hub bearing, involved virtually all new parts, as compared to the earlier final drive design as fitted to the D4 9G, 7J and earlier 2T series tractors, up to 2T8269.
    The only part I can find common, is the inner spocket taper roller bearing. Here's the two pages from the parts book, you can do your own comparison ..
    D4 7J series final drive .. http://img24.imageshack.us/img24/6505/d47jfinaltg2.jpg
    D4 late 2T/5T series final drive .. http://img24.imageshack.us/img24/196/d45tfinalhu3.jpg
  1. Need Help with WIDE RD6 Final Drives
    By D8PETE in forum DISCUSSION
    Last Post: 03-03-2008, 10:34 AM
  2. Cat High Ten Runs And Drives...but
    By Catmatt in forum DISCUSSION
    Last Post: 12-29-2007, 06:02 PM
  3. Final Drives Big Cat 20
    By drarv in forum DISCUSSION
    Last Post: 05-25-2007, 06:56 AM
  4. Final Drives D69U
    By Joel59 in forum DISCUSSION
    Last Post: 05-15-2007, 08:38 PM
  5. D8 Drives Poorly When Hot
    By hb11 in forum DISCUSSION
    Last Post: 03-11-2007, 07:07 AM
