Thread: Oil Leak at governor
    Sep 2007
    Cambridge city in.
    57
    Default Oil Leak at governor
    On my D7-3t I seem to be to have a oil leak in between gov. housing and block at the throtle shaft would that be seal 7B556
    From the parts book I can not tell if Iam on the right side
    CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
    CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
    CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
    And some old AC tractors
    Looks right to me...that shaft doesn't come through the front side.
    303
    Napa number for that seal is NOS6372.
  1. D2 Pony Motor Oil Leak
    By Cysco in forum DISCUSSION
    Last Post: 05-13-2009, 04:29 AM
  2. D6 oil leak
    By m rust in forum DISCUSSION
    Last Post: 04-12-2009, 10:58 PM
  3. 1942 D4 pony oil leak
    By Suomalainen in forum DISCUSSION
    Last Post: 04-08-2009, 10:56 PM
  4. oil cooler leak D-4
    By sidehill6600 in forum DISCUSSION
    Last Post: 02-01-2009, 08:48 PM
  5. Oil Leak on 17 A
    By ali sleiman in forum DISCUSSION
    Last Post: 01-10-2008, 03:15 PM
