Just got this one in the other day. But of course it didn't run. After a couple nites of checking things over cleaning a couple things it purr's like a kitten. This spring I got 50 acres im going to disc with it. Should be fun! Mike
Mike, that is a spiffy looking 35. I'd love one. Is your pony start handle removable? I'd strap it up if not. You wouldn't want to hook it on something. The results could be costly. Get more pictures. By the way, where in Ill?
933 42A, D4 7U, 2- D2 5U, 2- D2 4U, PV 15, LaPlante Choate C-20 scraper, and always with an eye out for more![]()
Mike and Matt that 35 looks good. You should get some work done with that. I will give you a call. You have to hood for the crawler![]()
That Diesel 35 is in great shape! Has it been in a barn for the last 70 years? I wish mine looked that good when I first got it. Thanks for the picture.
Very nice tractor, should sound good working.
D2 5J2115SP
D2 5U7066
D6 2H3072
No.9 Auto Patrol 8A331
No.9 Auto Patrol 8A539
Minneapolis-Moline prototype crawler X253
1945 Farmall H
1923 Fordson on Trackson crawler conversion
The person that dropped it off forgot to give me the crank handle for the pony. So I just migshifted one together quikly. I do have the hood. Just had it off to bleed the lines going into the injectors. I am going to machine a pully for the back side of the engine fan and put a hydraulic pump on it. Mount the pump where the lighting generator is supose to go. So I can pull a hydraulic disc. Im in the quad city area. Mike
I think I have seen that tractor before?
Jeff
