Hi all just got my 955 running it is serial 60A10641 all checks out ok but after running it for about an hour there is a loud noise when you put trans in netural and are down at idle speed it appers to be coming fron the control valve and not the pump area. When put in gear forward or reverse it goes away then back into netural it stays quiet untill you throttle up a little. It sounds like a buzz or maybe gear mesh? The fluid is clean and full. Any ideas ? Thanks in advance. Larry
