Results 1 to 7 of 7
Thread: d6 9u governor rebuild
    Sep 2008
    Marion Center,Pa
    48
    Default d6 9u governor rebuild
    I'm trying to figure out what parts wear and need replaced I know the spring and I checked with cat its discontued but what else in there needs replaced any help would be greatly appreciated thank you Dave
    Mar 2007
    Richmond Hill Ontario
    602
    A guy down in Mo. just did his governor, can't remember his handle maybe yellercat.
    Later Bob
    Default Gov.
    Usually if it,s got lots of hours on it the weight rollers get flat spots on them and sometimes the pin in them and the weights themselves pins and bushings get worn and the bearing on the end of the shaft in there. It,s almost a seek and find just what parts are worn if your doing a complete overhaul. The best spring I found for them is a 5F 6413 and also other engines with the style gov. that uses that type spring.The idles, high and low will need to be checked esp. with a new spring.I have rebuilt a truck load of governors and that spring worked the best for power and found that out from one of our older engine mechanic.
    Sep 2008
    Marion Center,Pa
    48
    No springs are available from cat anymore any suggestions where to find one
    Colorado
    362
    db1az18,
    What is the Sn of your D6-9U?
    Kelly
    Old Caterpillar Watch Fob.
    Without history, a society shares no common memory of where it has been, of what its core values are, or what decisions in the past account for the present circumstances.
    Sep 2008
    Marion Center,Pa
    48
    It is 9u12844
    Jul 2008
    ms
    91
    Default spring
    heavy quip
  1. D2, D4, D6 Pony Governor Observation
    By John from Fresno in forum DISCUSSION
    Last Post: 03-14-2010, 03:45 PM
  2. Oil Leak at governor
    By greyhead in forum DISCUSSION
    Last Post: 03-20-2009, 09:31 PM
  3. D2 SN# 4U1722 governor question
    By Sargosailor in forum DISCUSSION
    Last Post: 04-08-2008, 07:14 PM
  4. 315 governor
    By waukman in forum DISCUSSION
    Last Post: 07-30-2007, 08:36 PM
