Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: D2 Generator to alt conversion
  1. #31
    California
    287
    I’d have to agree with The Old Magnet has posted here.
    With a two standoff approach floating in space there are major problems in the kinematics or lack there of beyond taking care of the inherent vibrations that Old Magnet has mentioned. There is nothing to control the yaw axis movement. You are relaying on the accuracy of the spot face on the two mounting standoffs to control that movement. The lower die cast hole in the Alternator being longer might give you some yaw axis control, but that hole is seldom coplanar with the axis of rotation of the rotor.
    Anyone who has worked with GM automotive starters knows why they sell eccentric studs and tapered shims to go with those starters. The alternators are not any better in terms of mechanical repeatability as there is a huge variation in the mounting arrangement that must be adjusted for axially. These GM housings are poorly die cast but in the original application that is not as much of an issue as a belt driven arrangement can mitigate a lot of axial and angular misalignment that goes beyond what a Love Joy coupling can accommodate.
  2. #32
    Fresno, California
    244
    Default CME Alternator Adapter
    Here is an adapter made from aluminium.
    John
    Attached Files Attached Files
  3. #33
    Nov 2009
    Lindsay, Ontario
    131
    Have you tried to search their web site to get more information?? yuk!
    does anyone know what their bracket/kit sells for??
    rod
  4. #34
    Sep 2009
    Gilroy, CA
    355
    Quote Originally Posted by rditz View Post
    rod
    $400 plus shipping last winter.
  5. #35
    7,043
    Hi Mike,
    Did they give you any choice of alternator...Last one I knew about came with a Leece Neville unit....what a prize.
  6. #36
    Sep 2009
    Gilroy, CA
    355
    I bought it but did not install it. I think you are correct. Probably have to replace it with a Motorola one of these days. I saw another post re whether Delco was a good choice. I have been told that Delco will not hold up either due to a lack of cooling.
    We bought the same unit over ten years ago with a Motorola and never had any problems. Had to get the tractor out of the shop and put it to work.
  1. gen to alt
    By yancy44 mag in forum DISCUSSION
    Last Post: 03-24-2010, 09:00 AM
  2. generator on a r2
    By deetwocat in forum DISCUSSION
    Last Post: 02-04-2010, 05:09 AM
  3. D2 Generator
    By Cysco in forum DISCUSSION
    Last Post: 10-05-2009, 11:26 PM
  4. Alt source of bleed line leak D6-9U
    By yellercat in forum DISCUSSION
    Last Post: 08-18-2008, 09:19 AM
  5. D47U Generator conversion
    By slimfin in forum DISCUSSION
    Last Post: 12-19-2007, 03:04 PM
