Well I'm back askin for help on this machine again. I adjusted the clutch because it didnt lock in and I just ran it this morning after I changed the engine and transmission fluids and tried to grease all the little points I could find along with one that was pointed out here. Trouble is the clutch doesn't lock in or have a snap to the lever that I can tell and that's why I was adjusting it in the first place. I pulled off the floorboards and the transmission interlock lever wasn't hooked up. Thought that was it. Stood on my head again and got that all hooked up and still no clutch lock in. Anybody have any suggestions? I don't want to change the lever length but it looks like that may have already been done as I cant get it to lock in no matter how hard I pull the lever. I also noticed where the clutch lever goes thru the housing is kinda wallered out some. Any suggestions would be greatly appreciated.
Thanks to all for all the help. I finally got it adjusted and now works great. Got some engine vibration but will check out that later this weekend or next week. Still have to adjust the brakes some more and may have to use a thicker oil in the turning cluthes hydrailic assist unit as it leaks down while turning but at least it will push dirt now. Thanks again for the information.
