I am having a problem with the diesel motor valve adjusting procedure on my 1956 D2. The valve part I can do but my question is how do you rotate the engine by hand ? I have a front mount hydraulic pump that comes off the crank so using the crank damper bolt is out I assume. The manuals I have don't provide any info that I can find. Any help will be appreciated....Bill
