I have a D65R with a 4600 motor in it. Its leaking oil behind the oil filters. I took off the front filter to look at the oil manifold tube,there was no holes in it that i could see. Did find the oil cooler lines bent just about closed. Would the bent lines cause to much pressure and blow out the gaskets? Was not leaking last time i used it about 4 years ago.
