Results 1 to 1 of 1
Thread: Cat 2S blade repaired - again
    Kerrick, Minnesota
    487
    Default Cat 2S blade repaired - again
    Some of you may remember last January when I installed the 2S blade on my freshly painted D2, I discovered too late that it had been modified to fit a prevoius application. Someone had removed the upright sections the hydraulic cylinders attach to and re-welded them farther forward to accomodate different cylinders. I didn't notice it at the time, but found out later that with factory cylinders I couldn't get the blade to touch the ground.
    It's finally warming up outside so I got the Cat out the other day and took the blade back off to return it to original condition. I carefuly removed the old welds and got the uprights off the frame. Cleaned everything up, prepped for re-welding and ground all the shiny paint from where they needed to be re-attached. After using the measure 16 times and weld once rule, got them back where they should be. Now all I need is a weekend above 60 degrees (farenheit) to paint and maybe I'll be done this time.
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
  1. Cat 30 Wm. Bros Blade Revisited
    By powergiant in forum DISCUSSION
    Last Post: 05-05-2009, 09:36 PM
  2. Cat 30 Blade
    Last Post: 04-29-2009, 09:34 AM
  3. Weights of Cat 22 with blade and D2 with blade
    By Peter C in forum DISCUSSION
    Last Post: 10-20-2008, 10:19 PM
  4. I have two Mags that need repaired
    By 2-22dud in forum DISCUSSION
    Last Post: 12-10-2006, 07:17 AM
