Results 1 to 10 of 11
Thread: Caterpillar ten Thermostat installation
    Pennsylvania
    281
    Default Caterpillar ten Thermostat installation
    Is this the right way to install the thermostat in the cat ten. Pictured is the upper radiator pipe with the thermostat.
    Matt
    Default Thremostat
    If that pipe is the one going to the radiator as it looks like it is then in upside down.The spring part and senser always goes toward the engine block.When it opens then the coolant can go to the radiator for cooling.
    Pennsylvania
    281
    Like this....
    Oct 2008
    Long Island N.Y
    362
    Post Thermastat
    Matt the second pic is how mine was when I took apart
    Default Thermostat
    Yes Matt, the 2nd. picture is right way now.
    Perth, Western Australia.
    897
    The gas-operated piston (that is visible on the top of the first pic) is the device that needs to be in the heated water to make the thermostat open.
    Thus, it has to be on the bottom, where the hot water is coming from the engine, for the thermostat to work as designed.
    Elkhorn, WI
    1,645
    Default Part Number?
    Does anyone have a part number on the thermostat used in this article?
    Aug 2007
    Qld Australia
    134
    Default Therostat Part No
    My 15 Book shows Part no L-1118 That translates to todays No of 0L1118 . I havn't ever checked whether they can be Bought or not , I would be supprised if The 10 isn't the same number , I just haven't a Ten book with Me at present . You should be able to pickup something from like's of Nappa over there .Good luck LJ
    Morgan Hill, CA
    159
    Default Thermostat for 10, 15, 22 etc.
    Here is the instructions and number of the thermostat. It was still available from Cat a few years ago. It doesn't look like the picture though, it is a lot lighter made with no O ring. The picture is of an older NOS Thermostat. It also does not come with any instructions. - Wally
    Elkhorn, WI
    1,645
    Confused
    I assume the part number on the paper is the cross from the part number on the NOS T-stat?
  1. Caterpillar Ten Final Drive
    By Catmatt in forum DISCUSSION
    Last Post: 04-21-2009, 05:40 PM
  2. Caterpillar Ten Rail Height
    By JasonPayneCrawlers in forum DISCUSSION
    Last Post: 01-16-2009, 08:35 AM
  3. Caterpillar Ten Pics
    Last Post: 01-02-2009, 09:13 AM
