Thread: D2 track adjusters
    May 2008
    Arlington Washington
    9
    Default D2 track adjusters
    Does anyone know of a D2 track adjuster conversion to the newer grease gun adjuster? I was going to rebuild mine and a friend said he thought someone made them. Thanks
    7,113
    Check Kroenig Tractor in Amity, Oregon.
    They used to offer the hydraulic adjusters.......but check close. The one customer I know was not a happy camper. Seems all you get is a fabricated hydraulic cylinder and adaption, plumbing etc. was up to the customer. This set never got mounted so I don't know if they fit or worked right.
    Wouldn't be that difficult to make your own.
  1. D2 5U track adjusters?
    By Diamond-Ranch in forum DISCUSSION
    Last Post: 07-13-2009, 08:57 PM
  2. Track bolts
    By brialin in forum DISCUSSION
    Last Post: 04-30-2009, 03:18 PM
  3. D2 5U Track Adjustment
    By 2bluejon in forum DISCUSSION
    Last Post: 03-22-2008, 04:23 PM
  4. D2 Track Chain
    By Roverman in forum DISCUSSION
    Last Post: 02-01-2008, 05:55 PM
  5. d6 9u track tension
    By d7doug in forum DISCUSSION
    Last Post: 01-18-2008, 08:19 PM
