Thread: pv15 serial # location
    Mar 2007
    Martin SD
    27
    Default pv15 serial # location
    I have a pv15 and plate is gone from seat. but is there other places it might be stamped, into engine or main case? thanks all Paul
    Baltimore, Maryland
    64
    Look on the flat spot where the generator would mount on the front left side of the engine, on the right headlight mount on the radiator or on the flat spot on the left side of the inspection cover right behind the steering clutches.
  1. 2 ton serial number location?
    By kiwicats in forum DISCUSSION
    Last Post: 09-18-2009, 03:31 PM
  2. Another PV15 for serial record
    By equipdriver in forum DISCUSSION
    Last Post: 07-27-2009, 02:48 PM
  3. Serial number location on Cat 30
    By AndyD2NZ in forum DISCUSSION
    Last Post: 01-14-2009, 01:24 AM
  4. cat pv15 tail seat decal location
    By miked238 in forum DISCUSSION
    Last Post: 08-08-2007, 09:46 PM
  5. Serial Number Location on 3406
    By Art From De Leon in forum DISCUSSION
    Last Post: 06-30-2007, 07:56 PM
