Results 1 to 6 of 6
Thread: d6 9u question
    Jun 2008
    new hampshire
    80
    Default d6 9u question
    While cleaning up the surface where the transmission mounts to the final drive case, I found the surface to be slightly pitted, was wondering if there is a reccomended sealer to go on the new rubber seal. Would hate to have it leak after all this work. Any info would be greatly appreciated.
    Jan 2008
    MELLEN WI
    195
    I think I'd use permatex ultra black.
    Jun 2008
    new hampshire
    80
    not farmiliar with that product is it like the #2 NON HARDENING?
    7,049
    I'd use this stuff:
    Jan 2008
    MELLEN WI
    195
    Permatex ultra black is a hardening RTV. http://www.permatex.com/products/Aut...sket_Maker.htm
    I've had the best luck sealing with ultra black.
    Jun 2008
    new hampshire
    80
    thanks for the info guys
