Thread: Cat hauler
    PA
    42
    Default Cat hauler
    Can anyone suggest a solution to a problem miss in the 335 Cummins engine
    in our Mack LTH Cat hauler? One cylinder misses at idle when the air pump
    is pumping and smooths out as the air governor cuts out. The compressor has
    its own external intake filter and does not take air from the aftercooler.
    Also equiped with a three stage Jake brake. Suggestions appreciated.
    Thanks, Lou
    Madera, California
    55
    It is possible that you notice the miss when the air compressor is pumping because of the lower rpm. It is possible that you have an injector that is bad. Pull off valve covers and cancel out each injector indivdually. Listen for the cylinder that does not change in sound. It could have a bad lobe on the camshaft, 335's with Jakes were bad for this.
  1. New Cat Hauler
    By Packrat in forum DISCUSSION
    Last Post: 04-09-2010, 06:18 PM
  2. New Cat Hauler
    By Jason 10/D4 in forum DISCUSSION
    Last Post: 04-09-2010, 01:44 PM
  3. Maybe my CAT Hauler
    By John in Wy in forum DISCUSSION
    Last Post: 02-17-2008, 07:38 AM
  4. OT Old cat hauler
    By Jdnut in forum DISCUSSION
    Last Post: 09-06-2007, 06:43 PM
  5. New Cat hauler.
    By Garlic Pete in forum DISCUSSION
    Last Post: 02-26-2007, 05:31 PM
