Thread: D2 5U roller question
    May 2008
    Arlington Washington
    9
    Default D2 5U roller question
    I have new double flange rollers but no new single flanged ones and was wondering if anyone has heard of cutting the inside flanges off on a lathe as to make a single flanged roller? Can it be done? How hard is the steel?
    Thanks Larry
    NW California
    250
    I cut down several sets of the double flange rollers on a lathe, tough and slow, but worked ok. The shavings that came off were very tough and very sharp, the slightest touch and they would cut.
    May 2008
    9
    Thanks Josh I had a friend with an old lathe that could not even make a scratch on the flange. I guess I'll take them to a machine shop.
    Larry Diamond
    Covington, WA
    144
    You'll need carbide tip cutters to even touch these.
    Kevin
    Perth, Western Australia.
    897
    The gas axe is the cheapest and most economical method. After all, no-one's going to look at 'em, and pick holes in your finish..
  1. 5 roller D2
    By tracknut in forum DISCUSSION
    Last Post: 04-25-2009, 09:42 PM
  2. track roller lubrication question
    By grayrat in forum DISCUSSION
    Last Post: 11-13-2008, 03:26 PM
  3. D6 9U 3405 Roller Question
    By First Cat in forum DISCUSSION
    Last Post: 10-19-2008, 04:46 AM
  4. D2 5U roller question
    By Diamond-Ranch in forum DISCUSSION
    Last Post: 05-04-2008, 08:59 PM
  5. D2 track roller grease question
    Last Post: 04-12-2008, 06:46 PM
