Results 1 to 4 of 4
Thread: Timing On Pony Motor On D6 9u
    Jun 2009
    ohio
    6
    Default Timing On Pony Motor On D6 9u
    Good afternoon , The impuse coupling broke on my distributor and I installed a new one on my pony motor , Now when I turn it over evertime it goes to fire , the starter almost comes to a complete stop and then with turn over fast again , I can get it to start , but I think it is a little out of time, can I adjust the mag ?
    Thank you
    sorry I POSTED THIS IN THE WRONG FORUM
    1,786
    Unless you are a tooth off on you timing when you installed the mag and you need to correct that, you cannot adjust the magneto timing.
    Sounds as if your battery or starter motor is sort of weak.
    7,055
    If your mag housing has the slotted holes some minor adjustment of the point opening (and timing) can be achieved by rotating the unit to where the points just begin to open for the #1 firing position.
    Any time major work has been done to the mag the edge distance should be checked and reset if needed.
    When you changed the impulse unit did you match the replacement with the exact same parts....there are different degree advance units.
    Jun 2009
    ohio
    6
    Thank you for the imformation , I will check to make sure I have the gears lined up correctly , when I changed the magneto everthing looked the same , i didnt think that there were differnent advanced degrees ,
    I will look at it and let you know
    Thank you for the help !
  1. Pony Motor Timing
    By Don Clark in forum DISCUSSION
    Last Post: 03-10-2013, 07:22 PM
  2. D4 Magneto timing to Pony
    By auscuscus in forum DISCUSSION
    Last Post: 02-28-2013, 05:44 PM
  3. Timing starting motor for Cat 12 8T10279
    By mvoth in forum DISCUSSION
    Last Post: 01-20-2009, 10:46 AM
  4. timing mag on pony motor
    By Doug Swenson in forum DISCUSSION
    Last Post: 09-10-2008, 08:19 PM
  5. pony mag timing???
    By bobcatfour in forum DISCUSSION
    Last Post: 06-19-2008, 10:15 AM
