I'm converting the hydraulic system on my D6D SA from an "open" center type to a "closed" center type. The fittings on the original open center hydraulics that came with the D6D use JIC hydraulic fittings while the fittings on the closed center components that came from a Caterpillar AG 6 use O-ring boss hydraulic fittings. Is one better than another and when should one be used rather than the other?
