Thread: D2 Oil Lines
    Jun 2008
    Marion, NY
    151
    Default D2 Oil Lines
    Need info on D25J orientation of the oil lines from the oil filter base to the oil cooler. Does the innermost line go to the top or the bottom fitting on the oil cooler. I can't make heads or tails out of the flow diagrams in the service manual. Thanks for any help. John
    Williamson, New York
    125
    Default Old Line layout
    Oldparker,
    What model D2, I have a D2 5U in Sodus. I would be willing to have you come over and take pictures, sketch what you need. Give a call, 585-356-4264 (Tim)
    Covington, WA
    149
    Quote Originally Posted by timbo1946 View Post
    Oldparker,
    I just went out and looked at my 5U and the inner one goes to the top fitting on the cooler and the outter one goes to the lower fitting.
    Kevin
    1,821
    Parts book seems to indicate the J series is the same, inner/upper on filter base goes to upper on oil cooler.
    Jun 2008
    Marion, NY
    151
    Default D2 Oil Cooler lines
    Thanks for the help guys. It really had me stumped. Mine is a 5J model. John
  1. Fuel Lines
    By Cysco in forum DISCUSSION
    Last Post: 09-18-2009, 10:37 AM
  2. How do u protect open injector lines/
    By Knucklebuster in forum DISCUSSION
    Last Post: 10-31-2007, 09:02 AM
  3. New D2 Oil Cooler lines
    By Jdnut in forum DISCUSSION
    Last Post: 02-19-2007, 09:23 PM
