Can someone tell me what the name of this fuel line fitting is. It is off of my D4 7U fual line. I want to remake the line and go to stainless steel.
Can anyone tell me what the thread pitch is on the nut that threads into the hour meter where the fuel line goes in?
tubing Ferrule
Here is a picture of an adapter I made years ago to adapt from the cat housing to -8 AN (-8 JIC) so I could use Aeroquip steel braided fuel hose... you know for that dragster look![]()
The taper on the Cat fittings originally had two angles with a radius at the intersection. I'll have to dig through my notes for the info if you need it.
I got the info 1st from measuring multiple fittings on an optical comparator, then got the actual tooling & drawings from the former supervisor at the screw machine shop that was in San Leandro, CA
I don,t know if the correct name is ferrule but that,s what we called them at the shop.They may call them a sleeve but not sure as the picture I have isn,t too clear as to what it is.
After screwing around with all kinds of fittings and adapters to match Cat's odd ball design I have found a -10 "O" ring boss fitting to what ever line or hose you want works just fine. The thread is 7/8-14.
Thanks guys, I could have did all the leg work like you guys did, but I was certain someone already went down that road.
Buy? I made the center fitting out of 316 Stainless steel on a hardinge lathe.
Why 316... Because I had it in hex stock at the time.
The top fitting is a 1/2" pipe to -8 JIC taper that I got from Motion Industries.
The bottom fitting came off an old caterpillar, probably in a junk pile.
The only issue you might run into using an O-ring boss fitting is the sealing surface of the o ring might end up on some uneven casting, you might have to do some hand lapping. It really should seat into a 15 degree boss with a minimum of a 8 microinch finish, however with the low pressure involved with a gravity fed fuel tank it should be fine. If you look at this thread http://www.acmocbb.org/ACMOC_BB/showthread.php?t=6829 you can see a picture of an aluminum manifold I made that accepts the O-ring boss fitting.
That being said there is nothing wrong with that fix. I have made plugs for my oil cooler (also 304 stainless) that use a captured face seal O-ring right onto the casting of the oil filter housing and it does hold 30 psi more pressure than the fuel tank.
The bulkhead fitting will work.....but not -8....as stated before it is a -10 size (7/8 inch -14 straight thread).
I tried it but I didn't like it as it sticks out way to far.
Oil filter/cooler plugs do not have to be fabricated and using pipe plugs is not a proper fit. I have found that you can use -10 "O" ring face seal fitting along with a "O" ring boss "O" ring (1 inch - 14 straight thread)
