Results 1 to 7 of 7
Thread: D4 Steering Clutches
    Mar 2008
    Monongahela PA
    23
    Default D4 Steering Clutches
    Hey Guys;
    I would like to know what you guys use when setting up the ring & pinion gear,The book says to use red lead? I went to NAPA they can't get it.What about white grease will this work? Or is there something that will work better? Also does anyone have a set of the oil cups for the throwout bearing that mount in front of the seat? I would like to have a set. Thanks again STEAMROLLER
    Kerrick, Minnesota
    487
    There is a marking compound made specifically for the purpose of checking gear contact patterns, I've seen it come in white or yellow colors. It works better than grease because it covers the gear teeth really well but is thin enough that only the actual areas contacting each other show up in it. I've compared grease and marking compound on the same ring and pinion job, the grease made it look like a good contact but the marking compound showed the actual mesh a lot better, and made it apparent more adjustment was needed. The trouble I've found with using grease is it usually wants to drag onto the contacting teeth, making the contact area look larger than it actually is. I think NAPA would carry the marking compound, if not you can get it from any business that specializes in automotive differential/drivetrain components, that's where the stuff I use comes from.
    D2 5J2115SP
    D2 5U7066
    D6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    Covington, WA
    144
    What you need is called marking compound. Here is a like to Jegg's listing.
    http://www.jegs.com/i/Richmond+Gear/...07-1/10002/-1#
    And a listing from eBay http://cgi.ebay.com/ebaymotors/MARKI...Q5fAccessories
    Kevin
    1,779
    Usually if you ask for "prussian blue", you will get something even from the autoparts stores where the counter help doesn't actually have any experience working on machinery. Last tube I bought was a Permatex brand product I believe.
    I have used a soft black coating in aerosol cans that is sold for coating plows etc to stop rusting when not being used. It doesn't ever harden like regular paint and can easily be washed off with gasoline when you're through. It does take a little more resistance applied to the driven shaft to get it to make a good mark.
    Eastern Oregon
    965
    I've used white lead (used to be able to get it at hardware stores for plumbing) a few times but Prussian Blue wiped on fairly thin works about the best. Just about any automotive store will have it. .
    California City, CA USA
    187
    Default 'Bearing Blue'
    I've heard it referred to as 'bearing blue'.
    Daron
    Oct 2007
    Virginia
    253
    Go to Ben Franklins (or some art supply store) and buy some prussian blue oil paint. I use that when hand scraping (such as scraping a lathe bed, engine head, etc) or aligning gears.
  1. D2 5U Steering clutches
    By R4pat in forum DISCUSSION
    Last Post: 05-20-2010, 03:16 PM
  2. D2 5J Steering clutches
    By Dogger in forum DISCUSSION
    Last Post: 07-12-2009, 07:04 AM
  3. D2 5U Steering clutches
    Last Post: 07-01-2009, 06:45 AM
  4. D4 Steering Clutches
    By steamroller in forum DISCUSSION
    Last Post: 06-07-2009, 04:31 PM
  5. steering clutches
    By Stuss in forum DISCUSSION
    Last Post: 06-14-2007, 08:42 AM
