Results 1 to 10 of 12
Thread: rd7 pony weak spark on mag
    Oct 2007
    kansas
    11
    Default rd7 pony weak spark on mag
    been working on my new aquisition to day got the valves unstuck on the pony
    got good compression. Took the mag off and cleaned the points polished up all the contacts got fire but not real strong.
    Can hold the wire and crank over it will give a good through the shoulders jolt but not the throw your hands in the air jolt that it needs.
    took it back apart changed out the condenser but still same
    I am pretty sure it is not the correct mag for the machine but it must have worked in the past It is a fairbanks-morse x2a36
    any suggestions would be helpful
    thanks
    Apr 2009
    N IA
    130
    Default weak mag
    My experience W RD mags has been the rotor seems to go bad & bleed some spark to ground- although have had coils go bad but that usually results in no spark real quick-new rotors seemed real pricey so-- my cure has been to redo dist from slant 6 plymouth & convert to chrysler electronic ign..- same cure on pony on 2U's & 13000..
    oregon
    149
    how far a gap will it jump? though i do not grab my wires to test, your crazy!
    if it will jump 3/16 of an inch your good. i would try it to see if it will run.
    a fairbanks is the only mag i do not have. i like the cat mags but i bet the
    thing will run. some of my mags are weak, but still seem to run.
    Feb 2007
    Ste-Julie
    427
    Default rd7
    I am not sure but the rd7 should have a EISEMANN magneto
    Oct 2007
    kansas
    11
    thanks guys
    there is no measureable spark gap jump that is why i checked for spark with the old nerve endings
    im going to dig around and see if i can find another mag
    Oct 2007
    Virginia
    253
    Does this mag have the impulse coupler? Kicks the rotor around quicker? Is that working?
    I had a 17A with no spark and it ended up being the coil. Coil was pricey 10 years ago. Probably more now.
    You should be able to get a good 3/16" spark or so by just spinning it by hand bench testing. You have solid copper plug wires that are good? Cap is clean inside? Bench test it using a solid wire from the plug hole to mag case, holding the wire with pliers for a spark gap.
    If you can't get a good spark bench testing, then no use cranking the pony.
    Feb 2007
    Las Vegas, NV
    31
    Hi guys. I don't post on here but this one needs attention.
    Besides the usual suspects, the snap coupler (presuming it has one) needs to be good as said. The biggie with most all mags is the magnet itself. It's old. And weak. And can be recharged. There are people out there who will spiff it up for you and make life all sparkly again.
    My two bits,
    Gary M
    7,049
    It would help if you posted the serial number of the tractor.
    The RD7's had a variety of Eisemann mags....including the ones with the mechanical timing advance (lever on side of mag).
    Pittsford NY
    518
    Gary,
    there's a sticky on the ACME site with a list of vendors - can you post the contact details of the magnet fixer-uppers on to that sticky for us?
    Neil.
    Neil.
    oregon
    149
    original equipment was the eiseman. i have seen one fairbanks on an RD6.
    mine have eiseman, wico and cat. through the years people put whatever
    worked on them as the original failed.
    if you cannot jump a visible spark, it will not run. i have yet to see one that
    needed the magnets juiced, but have had a bad coil or two. can you hear the
    impulse click when you turn it.
  1. D4 Pony Spark Plug Sources
    By xzp0hy in forum DISCUSSION
    Last Post: 01-20-2012, 03:58 AM
  2. 9U Mag- no spark
    By Joel59 in forum DISCUSSION
    Last Post: 11-08-2009, 05:26 PM
  3. D4 mag, no spark
    By 3crows in forum DISCUSSION
    Last Post: 05-07-2008, 08:27 PM
  4. Spark Plugs D25U pony Engine
    By Al Letts in forum DISCUSSION
    Last Post: 02-16-2008, 09:53 AM
  5. pony ran great, now no spark and no start
    By nickspalding in forum DISCUSSION
    Last Post: 07-30-2007, 10:44 AM
