Results 1 to 7 of 7
Thread: A couple of questions for the jack hoses
    Nova Scotia
    122
    Default A couple of questions for the jack hoses
    A couple of things -
    1. I was wondering who would know what the minimum psi would be for the jack hoses on the Cat 44.
    2. I'm planning on removing the block on the left side of the fender where the hoses go into the jack and also going to replace the pipes with hoses and go directly into the jack with them. I wonder if anyone would know how much oscillation there would be for those hoses there. I figure maybe an inch?
    7,043
    Relief valve pressure setting on the #44 pump is 1200 psi
    Working pressure is 1000 psi.
    Single wire (R1 - 3/4 hose) is good for 1250 psi working pressure.
    Two wire (R2 -3/4 hose more commonly used) is good for 2250 psi working pressure.
    Sounds about right on your flex estimate.
    Maidenhead.
    299
    Novavalley or Om what is it you are refering to as the 'Jack' ?
    Regards Gordon.
    WALES UK
    438
    Hello Gordon,I think they mean hydraulic rams.Seen jacks written in a few books refering to rams.
    Regards
    Martyn
    Aveling Barford GA
    D2 3j
    D4 7j Dozer
    btd6 Drott X 3
    B100
    I H TD6
    Fordson major
    Fordson N
    Hydrovane 90
    7,043
    Yup,that's it Term doesn't come up very often but it is in reference to hydraulic rams.
    Nova Scotia
    122
    Son in law here,
    He has the pump sorted out for the front and is in the middle of refinishing that. The pipes used to run back both sides for the "jacks". He is removing the left set and only using the right set.
    The hose will go from the right block through the hose over into the left set. Thats also why he has to know how much movement there might be in the hose due to the lifting and dropping of the "blade arm" - my inexperience in parts showing through there.
    Thanks to Old Magnet - He was happy to hear his line of thinking on the matter was correct.
    Weird size requirements for the pic uploads I must say.
    Maidenhead.
    299
    Hi Martyn, Om, My common sense said is was, but i wasn't sure, Thanyou. Nova that is an excellent paint job. i'd be loath to get it dirty.
    Gordon.
  1. Bottle Jack Injector Testor
    By Old Magnet in forum DISCUSSION
    Last Post: 12-29-2009, 12:35 AM
  2. caterpillar hoses?
    By chriscokid in forum DISCUSSION
    Last Post: 05-15-2009, 03:07 PM
  3. New Member Couple Questions Pics of Bulldozer inside
    By Bighead38 in forum DISCUSSION
    Last Post: 12-16-2008, 08:07 PM
  4. Timber Jack Joe
    By John in Wy in forum DISCUSSION
    Last Post: 02-05-2008, 11:05 AM
  5. Couple Engine Questions - #9 Auto Patrol
    By Forcus in forum DISCUSSION
    Last Post: 05-16-2007, 08:19 AM
