Results 1 to 10 of 14
Thread: D2 brake drum source
    May 2009
    SC
    12
    Default D2 brake drum source
    I removed the steering clutch off of my D2. The whole thing had rusted into powder, the inner hub flange was broken off and covered with rust on the broken edge. I assume the expanding plates pushed hard enough to break the flange. I was able to get the final off without breaking the brake drum but there are many missing splines from rusting through. I got a used inner hub and discs from a member up north but he did not have any drums. I see that steeringclutches.com does. Has anyone ordered from them? Good place to deal with?
    Also, I was going to take off the large nut holding the throwout bearing but it is stuck tight as can be. I don't have a large spanner wrench but may have to make one. Any tips on removing or , in my case, tightening the nut?
    Jun 2008
    Marion, NY
    149
    Make sure the set screw on the inside edge of the nut is removed before putting any force on the nut. If things were so rusted up, you may not have noticed this set screw.
    Covington, WA
    145
    Check real close for the set screw, there maybe two of them. Take a wire wheel and clean it off real good.
    I picked up a complete set of drums (inner and outer) plus all of the disks from John at steeringclutches.com last year. John was real good to work with.
    Kevin
    Williamson, New York
    125
    Default Drums
    I ordered a main clutch disk for a D2, came broken, called and he shipped another without question. I would do bussiness with him again, no issues here. Hope it helps. I have a couple of drums, but I'm not sure that I want to get rid of them yet. If you get in a real pinch, we can talk.
    Tim
    Feb 2009
    ontario canada
    87
    Default dealing with john
    i had bought steering clutches from john at general gear i would call on him agean if i needed somthing . i have used the clutches for two years with no problems.
    Eastern Oregon
    966
    As I live in Eastern Oregon, I've dealt with John at General Gear in Boise ID 208-342-8911 and Bucky at Phillips Tractor in Gaston OR 503-661-3929 and have no qualms about referring anyone to them. What one doesn't have, the other usually does. Prices are fair and both give good honest descriptions.
    May 2009
    SC
    12
    Thanks for the advice, never noticed the set screws. I need to clean the rust off first.
    I ordered the brake drum from Steeringclutches.com, should be here today or tomorrow.
    Are there any tips on replacing the steering clutches. I have clutch pieces off the Cat and am ready to reassemble but I have a few questions.
    What order do the discs stack on the shaft or does it not matter?
    Any tips for how to compress the springs and place the keepers?
    I was going to center the discs by sight or should I lay the drum over the inner hub to center the discs then remove the drum and then do the springs and keepers?
    Once the inner hub is assembled how do I get it on the splined shaft? I do not have a 3/4 inch impact wrench but I may need to get one. I can just bang on a 3/4 inch breaker bar but I am not sure that would tighten enough.
    Same thing with the brake drum, am I going to need a 3/4 inch air wrench?
    Thanks,
    Elkhorn, WI
    1,644
    Default Tool I made
    I made a tool without seeing the tool that was available from CAT. I put the assembly together inside the brake drum to facilitate later assembly. Then when its all lined up I clamp it tight and pull it out of the drum. See the tool in photo's
    Jeff
    Covington, WA
    145
    If you don't have a good 3/4" or 1" impact wrench or a hydrolic cylinder to press the drums on you'll need a very good breaker bar with about 4 to 5 feet of cheater bar to get them tight enough.
    Kevin
    Oct 2007
    Chenango,Co. N.Y.
    117
    landreo,Look at the instructions Bruce Oz posted-I scanned the file and made a booklet to take to the shop http://www.antiquecaterpillar.net/AC...teering+clutch
  1. 212 Grader Brake Drum (Max Diameter)
    By 660 Scraper in forum DISCUSSION
    Last Post: 01-06-2010, 08:42 PM
  2. 955 12a33 Need Brake Drum
    By BOWTIEIH in forum DISCUSSION
    Last Post: 01-02-2009, 05:21 AM
  3. Need Brake Drum for 112
    By DEANO in forum DISCUSSION
    Last Post: 03-04-2008, 03:02 PM
  4. oil on brake drum
    By spencer d47u in forum DISCUSSION
    Last Post: 01-16-2008, 09:33 PM
  5. D-2 5U brake drum help
    By dead axle in forum DISCUSSION
    Last Post: 09-04-2007, 07:41 AM
