Thread: LaPlante-Choate hydraulic pump coupling single double roller chain
    Nov 2007
    Far Southwestern Iowa
    167
    Question LaPlante-Choate hydraulic pump coupling single double roller chain
    In thread Front Hyd Pump, http://www.acmocbb.org/ACMOC_BB/show...light=ARC+5016 post #2 carlsharp lists the part number for this oddball chain as ARC 5016 but does not mention the source.
    Does anyone know of the source for this coupling chain?
    The splined shaft is firmly rusted into the coupling half at he pump and engine. The chain at the pump end has been sitting in water for a while and could tolerate replacement. The standard 50-2 double strand chain will not fit between the outside of the radiator and the pump housing without machining on the coupling.
    Eastern Oregon
    966
    Nov 2007
    167
    Default What the chain looks like
    A picture being worth a thousand words, I went out and took one. The coupling chain is made from the standard parts of #50-2 chain but the center plates are not used and the pins are shorter. This has to be out there somewhere but I do not have a clue where.
    7,112
    As Carl said, that is an obsolete coupling chain. Might start by contacting a Link Belt rep. or someone that handles obsolete inventory (didn't have much luck with a brief google search)
    Did you try contacting Carl Sharp.....he seems to have disappeared also. Haven't seen a post in a long time.
    Nov 2007
    167
    Have not tried to contact Carl yet. He is running some auctions on eBay so he is still with us somewhere. Link-Belt couplings have been gobbled up by Rexnord and I will call the local rep Monday. That will probably go nowhere though.
  1. Laplant Choate Hyd. Pump??
    By quinq in forum DISCUSSION
    Last Post: 08-06-2009, 09:07 AM
  2. D6 Rollers Double and Single
    By Paul Georgiou in forum DISCUSSION
    Last Post: 11-12-2008, 02:59 PM
  3. LaPlante-Choate Pump Seal
    By carlsharp in forum DISCUSSION
    Last Post: 06-02-2008, 06:56 PM
  4. Roller lube pump
    By Manx Kat in forum DISCUSSION
    Last Post: 11-05-2007, 09:38 PM
  5. LaPlant Choate hydraulic pressure
    By Clint in forum DISCUSSION
    Last Post: 12-20-2006, 07:11 AM
