Thread: Cat Power unit 7S
    Mar 2007
    Ohio
    29
    Default Cat Power unit 7S
    Question - the 7S Power unit is the same same motor as a D311 that is in the D2 4U and 5U and the Cat 933 11A crawlers? If memory serves me to put the power unit motor into a crawler you have to use the oil pan and pick ups off a crawler engine as those have a pick up in the front and back while the power unit does not. Please let me know. Thanks.
    Nov 2007
    NW Ohio
    495
    Default 7S
    Yes and the governor spring may be different too.
    Default D311
    There are probably a lot of little things that will need to be swapped from industrial to the tractor engine. For the gov. it depends on the RPMs the engine was set up for and the gov. settings and spring etc.so will take some real knowledge of it,s setup to change over to a tractor.
    7,049
    If you can post the RPM rating of the engine I can get you the governor setup from the rack setting charts.
    Default Cat Power plant
    Check the oil pan part #, I had to swap pans on one of my D2's, Power plants do not use the pan for the spring support.
    Ken
  1. Cat power unit
    By moparman in forum DISCUSSION
    Last Post: 01-23-2010, 07:05 AM
  2. Cat 40 Control Power Unit
    By mvoth in forum DISCUSSION
    Last Post: 10-06-2009, 06:52 PM
  3. Cat d4400 power unit
    By SpragueM in forum DISCUSSION
    Last Post: 07-23-2008, 09:27 PM
  4. Cat Power Unit question
    By mkreh23 in forum DISCUSSION
    Last Post: 11-27-2007, 05:17 PM
  5. Cat Power Unit 4D1060
    By kellyb in forum DISCUSSION
    Last Post: 12-07-2006, 04:39 PM
