Results 1 to 6 of 6
Thread: Torque spec for injector hold down nut and glow plugs
    Jun 2009
    Moundsville, WV
    79
    Default Torque spec for injector hold down nut and glow plugs
    Can some one give me the torque specs for these parts, thanks.
    Default Torque
    If your talking about the capsule type small nozzle then the nozzle is just finger tight on the body and the hold down nut is 105 lbs.torque.
    7,049
    10 to 12 ft. lbs. on the glow plugs.
    Jun 2009
    Moundsville, WV
    79
    Thanks guys...that helps
    Jun 2009
    Moundsville, WV
    79
    Does anyone know the torque spec for the rocker arm and the valve clearance setting Cold, I found the Hot clearance setting
    Default Valve Setting
    I set 100s of engines and I always added .002"thousands to whatever the hot setting was for the cold setting.I never torqued the rocker arms but just tightened them up good and I just looked in an operators manual and it says just tighten them up so just tighten them up good but don,t break your arm on doing it so you strip the nut threads.
  1. How to test glow plugs
    By bcwayne in forum DISCUSSION
    Last Post: 04-15-2010, 11:03 AM
  2. Start/heat switch&glow plugs
    By poor farmer/logger in forum DISCUSSION
    Last Post: 04-13-2009, 08:28 PM
  3. Torque setting pony flywheel nut
    By Dozerman51 in forum DISCUSSION
    Last Post: 07-20-2008, 11:12 AM
  4. 17a with glow plugs?
    By dancat in forum DISCUSSION
    Last Post: 01-11-2008, 06:43 PM
  5. Direct start Pre-cup with broken glow-plugs
    By Dunefanatic in forum DISCUSSION
    Last Post: 01-05-2008, 05:59 PM
