Thread: Big Twenty questions
    Kerrick, Minnesota
    489
    Default Big Twenty questions
    I hauled home this big Twenty today, the engine is siezed but it has some really nice manifolds on it that will fit my No.9 grader so I had to get it. I've got a couple of questions about it though.
    First I noticed a square box on the lower right side of the engine, attached to the block in the area of the oil pump. It has a tube that comes off it and up throught he hood with a pressure gauge on it. Is this what the crawler oil pumps look like or is it some kind of add-on?
    The other question is about the gearbox that is attached to the rear. It's cast so it bolts on the rear end where the rear cover would go, and there is an engagement lever that sticks up under the raised seat. A chain type sprocket comes out the left side of it. The previous owner told me it had a log skidding boom on it at one time, and somehow this powered it. Does anyone recognize it? I'll attach some pics.
    D2 5J2115SP
    D2 5U7066
    RD6 2H1768
    RD6 2H3072
    No.9 Auto Patrol 8A331
    No.9 Auto Patrol 8A539
    Minneapolis-Moline prototype crawler X253
    1945 Farmall H
    1923 Fordson on Trackson crawler conversion
    the square box on the side is a oil filter , and the gearbox on the back was for a willamette -ernst single or double drum drive leroy
    Kerrick, Minnesota
    489
    Thanks for the info!
    D2 5J2115SP
    D2 5U7066
    RD6 2H1768
    RD6 2H3072
    1945 Farmall H
  1. Big Ash Stumps
    By farmerfred in forum DISCUSSION
    Last Post: 03-10-2010, 01:10 PM
  2. Twenty Two questions
    By MO-22 in forum DISCUSSION
    Last Post: 01-25-2009, 04:17 PM
  3. oh no..a big surprise on d-4
    By sidehill6600 in forum DISCUSSION
    Last Post: 12-01-2008, 07:14 PM
  4. D2 rescues BIG Brother
    By DCurrin in forum DISCUSSION
    Last Post: 12-22-2007, 06:03 PM
  5. A Big Thanks to CAT INC.
    By Catman in forum DISCUSSION
    Last Post: 12-13-2006, 12:44 PM
