D25J water pump shaft and bushing
I will ask the dealer tomorrow if these are available but I thought I would ask the experts today. Found shaft was deeply worn at the seal, and worn off center too. Impeller was rubbing at its edge because of it.
Center brass bushing was also very loose bore.
Anyone make these parts out there, or does Cat still sell them? I figured my old shaft is too worn to rebuild (spray).
Shaft part # is 4B3703 and bushing is 1A8733.
I figure I can get these made if not out there. Shaft is 14mm dia material. Does anyone have a recommended grade of stainless for the shaft? Original was plated it looks like.
Thank you,
Dan
Dan22 - 1936 22 Narrow, 1937 22 Wide, D2 5J, D4D
